1 - 20 of 22 Posts
I know i know, im not real good at this kinda stuff. I found the 4 bolts that bolt the bumper brackets to the frame.. what else to i have to take off to get the bumper off because it felt like it was still hung on something...let me know!
Im talkin about the front bumper by the way
so total, there are 6 bolts?
That's all that's holding it there. Just pull the sucker off ;)
Discussion Starter · #9 ·
...Well what the hell was I loosening?? I thought there were 2 bolts on each side there at the very end of the frame?? By the way tenn....Im getting that lift from neal
haha, the front is tricky..i was gonna take it off one time to pound some dents out of it. I stopped after i saw some tricky bolt things that i thought i would break.
Discussion Starter · #11 ·
ok, so bottom line, how do I take the front bumper off. Give me some instructions....
See my last post. You've got it, just pull.
Is he going to help you install it?
Discussion Starter · #13 ·
yeah he is. So I take off the 4 bolt there to the frame and just pull...right?? is that what im hearing???
Discussion Starter · #14 ·
he said he just had to figure out a day that he's off work and some buddies can help....he said he's got some work to do to his lift too so we'll knock it all out in one day
Discussion Starter · #15 ·
by the way tenn...are you doors off in that picture??
Yeah, I normally take them off before I wheel. My doors are about the only body parts on my truck that aren't damaged. I'm tyring to keep them clean so I can sell them next fall when the taco becomes a trail only rig.
So, you're talking about the front bumper? My bad, when you said 4 bolts to the frame it sounded like the rear. The front has the bolts at the mounts on the frame, then out by the fenderwells (right at the top corners of the bumper) there are some L-shaped brackets. You'll need a socket and a box wrench (10mm I think) to hold one side and turn the other. They tend to twist around so be careful, but it's not hard. Also don't forget to remove your turn signals.
Yeah I was supposed to help him add a spacer to his OME's last friday so we could go to Summertown on Saturday, but I got too busy. I told him I would come up and help when he got time, so we can probably knock yours out, too.
Discussion Starter · #18 ·
Yeah I Appreciate it. You know that marlin crawler just came out with tube doors for out tacos.....the are about 200 bucks plus shipping. not bad, I think Im going to pick some up about april in time for warm weather. nways, yeah i look forward to meetin you guys and seein yalls trucks. yall just let me know when yall are ready, im going to order shocks next week. what do you recommend for the 3 inc lift?? i was just going to get ranchos
Pull the plastic back under the front of the wheel well on each side for the 2 other small nuts you need to take off - 6 total
I've got the rancho's. There not great as far as ride (pretty stiff) but if you're on a budget they'll work just fine. Just call TOR or EOR in Murfreesboro. They can hook you up with part numbers/ordering.
1 - 20 of 22 Posts
