Well, I figured I would try my hand at a skid plate for the gas tank and here's the result. I gotta thank Brad for the inspiration. It's 3/16" and weighs in at a hefty 30 lbs. My only concern at this point is the rear OEM mounts that I retained. They are only 12 mm and I'm concerned about the load on them. I could always fab an additional mount for the rear at a later date. I did replace the forward 12 mm with 14 mm Grade 8 hardware. I did use the medium stength Loctite for all bolts. Always a learning experience and when I do my wife's ('95 Runner) there's some changes I will make. My next skid for the Taco will be for the transfer case. Stay tuned. Any criticism would be helpful.
In this shot you can see the two Grade 8 bolts that replaced the stock 12mm ones.
nice!!! i dont think people here know Brad though;), I was most impressed with the brackets he built. Looks like your fab is really coming along! one of these days we'll have to wheel.
Mike
looks really good, gives me some big ideas
Mike
Yeah - I was pissed I missed the In Ko Pah trip. Next time........
looks good man! You'll keep your 18 gal tank.... I wish i still had one. ;) my taco has a ~17 gal tank b/c of the dents.
You'll be fine with the stock mounting locations esp with new bolts.
Mike
I'm a Brad, but I'm not that Brad! I guess I'll have to go with another 'B'. Budbuilt. I just don't have those resources you have. That shit looks awsome! I can only wish. Great job.
similar to what I did but you might want to add to the front.
I only covered about 3/4 of the length of the tank after watching where I was taking hits ;) The leading edge gets the most pressure so I beefed that up the most.
bottom and leading edge is 3/16" and the sides are 1/8" welded and riveted.
your color looks cooler ;)
