I have a 1999 toyota Tacoma 2.7 inline four that dies and it starts but then dies and has coolant in the engine bay and the check engine, oil and battery light are all on. What is wrong?
Which side is wet? Check the seals on the wire grommets and check the evaporator box drain line tube on the passenger side firewall.Another question the same truck now has water in the carpet and wont dry. I know it isn't seals because all my seals are good. I had 1-2 feet of snow and the water got worse.Any idea what it could be?
front passenger sideWhich side is wet? Check the seals on the wire grommets and check the evaporator box drain line tube on the passenger side firewall.
Thats a major issue. I'm guessing you probably have more than one source of the leak. Sounds like you need to get in the truck and have somebody hose it down and check for leaks.front passenger side
front drivers side
rear drivers side
rear passengers side
ok thank youUpgrading the intake is a good move. Beyond that, not much else will yield significant gains short of a supercharger.
ok thank you. May the Fourth be with youLots of LED options out there. Its all preference. Don't shop by price though. Some of the cheaper lights will fail early.
For the 4WD swap, are you doing the work? If so, you need the front end parts, transmission and transfer and several other bits. Major parts alone can be at least $2500 depending on what you spend on the big items like transmission and transfer. Lookup SafetyDang's 4WD swap write up. He detailed it really well.
