1 - 12 of 12 Posts
:confused:
I replaced the front brake pads on my 03 prerunner and on the driver side i took the 4 bolts out of the caliper that pinch it together instead of the 2 main bolts that hold the caliper on the spindle and some fluid came out so i snugged the four bolts back up and procided with the 2 bigger ones and the pad replacement on both sides.
Ok knowing that i lost some fluid on the driver side only i blead the breaks but when i had my buddy pump the break peadle i turned the little nipple to release the pressure and all that came out was a blast of air and it did this a couple of times with a few drops of fluid that came out also. Now there is hardly any pressure in the brake pedal at all and it doesnt stop for shit.
is there more than one bleed nipple on the brakes?
Also my resivor is full what the hell do i do.
are you bleeding the brakes properly? you need to have him pump up the brakes....hold them down with his foot, open the bleeder screw... while he keeps his foot on the breaks, then close the bleeder screw.. . now he can release his foot and start to pump them up again.
then repeat, but if you take the foot off the brake while the screw is open it will just suck air..
Austin
joerunner said:
:confused:
Get the system bled by someone who knows whats going on. Have them adjust the rear brakes first. Get yourself a good power bleeder for future use like the Motive Systems unit. They are not too costly and well worth the money.
well i blead the brakes with the truck started and fluid came out this time with a ton of air but i got it all out and it is fine now. Damn that one had me worried. thanks for the help though
I would still take the truck in to a brake shop and have them do a "once over" on it. Unless you get all the air out of the system, it will show up at the least opportune time!
Brakes are not something you want to mess with if you are not 100% certain you know what you are doing!
you are not just playing "craps" with your life but also with the lives of your loved one as well as complete strangers!
rubberpants said:
then surely you should have known how to bleed brakes then right? :rolleyes:
you'd think so huh :dunno:
Since you removed the 4 screws on the caliper assembly, you might have broken that seal and rendered that caliper useless since it can't hold pressure. That might account for both the poor braking and soft pedal. I'd replace the caliper, bleed the brakes again, then see if that fixes the problem.
1 - 12 of 12 Posts
