1 - 10 of 10 Posts
New little something for you to add on to your rig.......and it's tuned right out of the box for you.
2005 - Current Toyota Tacoma Rear Hydraulic Air Bump Stop System
Overview:
Bolt on a set of ICON Vehicle Dynamics Rear Hydraulic Air Bump Stops to improve the on or off road capabilities of your 2005+ Toyota Tacoma when using maximum suspension travel. ICON’s race proven hydraulic air bump stops are tested, tried and true, from Cabo to Canada in all conditions. This vehicle specific tuned hydraulic air bump stop system offers both smooth engagement, maximum bottom resistance, and smooth controlled return while being used in extreme conditions. The true value to using a compression and rebound tuned bumpstop is the exponentially increasing force is smooth, not abrupt or harsh like the OEM bumpstop.
As part of the kit, ICON includes an industry first selectable install height for the hydraulic air bumpstop so up travel is not limited with use of an aftermarket thicker leaf pack. This allows you to upgrade your leaf springs down the road, and retain maximum up travel without having to purchase a new bump stop bracket kit.
Key Features:
• Bolt-on design using existing holes in frame for clean install with no cutting or welding
• Industry only Toyota Tacoma specific tune to maximize bottom out resistance while having smooth engagement as well as return
• Absorbs additional impact energy over the OEM rubber bump stop and returns the axle in a more controlled manner
• Industry only kit allowing adjustment for leaf pack height changes so uptravel is not lost
• Can be returned to stock
Bumpstop Features:
• Linear-digressive piston which compliment a bumpstop over the industry standard linear-linear piston. Infinite tuning options with valve stack, oil volume, and nitrogen pressure adjustments
• Anodized billet top cap, o-ring sealed back up cap, seal head and striker
• CAD Plated body for corrosion free service
• Urethane rod seal and wiper for long service life
• User serviceable
Tech Info:
• Factory rivet removal required
• Configurable design to maximize up travel with OEM or aftermarket spring pack thicknesses
• Includes bump stop strike pad that uses factory u-bolts to secure in place
• Install time 2 hours
System Components Included:
• (Qty - 2) 2.5" travel 2.0 hydraulic air bump stops
• (Qty - 2) Vehicle specific 2.0 bump stop mounts
• (Qty - 2) Lower standard spring configuration strike plates
• (Qty - 2) Bump stop spacer rings
• Necessary hardware
• Installation instructions
Options:
• 56105 - U-bolt flip striker plates
I like that set-up.
Do you plan on designing a kit for 1st gen's too?
Later.
what about 03 to 09 4runners and FJC?
Great.
This past weekend I installed a pair of your VS series shocks... the ride has never been better coupled with the Deaver 8 pack leaves.
Looking forward to this kit coming out for the 1st gens.
Thanks.
Later.
Glad to here your happy.....appreciate the feed back. We will def let you know as things transpire with this product.
Sorry for resurrecting and old thread.
Have you thought about using the mounting bracket to tie into a frame reinforcement system?
Discussion Starter #9
With all the testing we have done there has not been a need for any frame reinforcement. Obviously you can always push the limit, so if that is the case for you, having someone custom fabricate a full cage front to back will handle it. Based on what we have seen no one is really having this issue in general.
Are you guys planning a long travel system, for the tacoma, anytime soon?
1 - 10 of 10 Posts
