I have a 2002 Tacoma 4x4. By taking out the power outlet relay in the engine compartment, and doing the full time power outlet mod, I am assuming this leaves the ignition on low power source for another relay. I found small 22-18 A.W.G. male connectors made by Noble, and was wondering if there is any reason why I can't do this? If I do this, do I have to use the same power outlet relay's ground connection too, or can I just ground out to anywhere I want? Also, how many relays could be powered on by this ignition on power source, since they are low power? Has anyone done this? I know I can tap into the fuse box in the dash for an ignition on power source, but the engine compartment location could be useful also.
