You remove the screw in the center and I believe you slide the handle to the right( if driver side ) and to the left (if passenger side). Then remove rod from back of handle
if you mean that your handle will not come loose from the f'ing panel so you can pull it free...then you have to remove the screw from the backplate, pull the handle out about 1.5", then push the backplate towards the front of the truck...use some force, it has 2 nasty clips that hang on for dear life...slide the backplate over the handle....then you can take off the panel....and remove the handle by popping off the Jesus clip.
unless, of course, that was not what you meant...
Boheefus
