1 - 11 of 11 Posts
to pass inspection i need a new U Joint and front shocks. He wants 500 bucks to fix is that fair?
What kind of vehicle? I wasn't aware that some states tested your u-joints and shocks as part of a safety inspection....
in mass they do that during inspection too, if i was you, i would check to see if you do need new shocks and u-joint (both easy to find out) buy the parts you want, and fix it your self, easy fixes, then go get inspected, or go somewhere else where thell just slap a sticker on, they do exist if you look around.
that is crazy. I have never heard of someone doing all of that for an inspection. Down here, it is like a drive through. you drive up, hand them your paperwork and ten bucks, and they give you a sticker.
A driveline shop should be able to replace a u-joint for less then $100. Maybe you meant to say ball joint instead?
The front shocks aren't that expensive. Bilstein shocks for the front should run about $175 or so plus installation. So like $300 for the shocks installed.
My General rule of thumb.. NEVER have an inspection station repair anything that they find. There are a lot of shady shops out there. I once paid $40 for a license plate bulb and a set of wipers. He wasn't going to pass me without replacing the parts. I should've asked the cost before he installed them.
Take it somewhere else if you can't do it yourself.
WTF?????? inspection????
for once cali doesn't have the BS before the rest of the nation...in this case at all........as far as I know.
At my inspection last year the first place I went to quoted me about $1000 dollars to get it inspectable. I brought it to another place and it passed. I did keep in mind what the previous station had mentioned was wrong but it was a couple small fixes and I was good to go for much much less than $1000.
keep in mind not all shops are shady, but you should get a second opion.
and also shady shops will pass you if there's something wrong.
1 - 11 of 11 Posts
