1 - 20 of 38 Posts
My stock airbox was cracked where the tube met the box, so i went and bought an air raid intake. since the installation the exhaust has gotten significantly louder at about 3500+ rpm. It sounds really good, but it made a much larger difference than i would have expected. I was just curious if this was a normal result. Thanks in advance for any input.
:doh:
*sigh*
Alright...
Seeing how you haven't made any changes to the vehicle's exhaust system (that being anything from the exhaust ports on the block on back to the tailpipe) when you did the intake install, one can surmise that your extra sound is actually coming from the intake. You probably removed a bunch black plastic container looking thingies when you installed your intake. They're called resonators and those bits are there to lessen the noise coming from the motor out of the intake tract, which when left un-muffled, tends to be obnoxious to most drivers. Remember, Just because air is getting drawn into the motor doesn't mean that sound can't come out.
Yes it is normal, because the stock intake has parts to muffle the sound.
Even though it is an intake tube, noise does travel back in ignition firing pulses.
Even different mfg. of gasoline will make your truck sound different. For me, Costco gas ie. cheap gas will make your truck louder and Shell Premium will quiet my truck down. Racing fuel will make it purr.
just my 2 cents.
Oh, i always thought the chambers to muffle the intake were to quiet that sucking noise that the air makes when it's flowing through the filter. Shows what i know. :rolleyes: thanks for the input guys.
Umm yeah...still gonna get flamed anyway!!! you removed the whole intake assembly and replaced it with a straight tube...HELLO!!!
Thank you so much for your helpful input :flipoff1: Forums like this are for people who don't know much, such as myself, to learn shit. Your flaming doesn't do anybody any good other than entertaining yourself.
To the rest of you who answered my question. Thanks.
:bs:
BS?! Buy some racing fuel and run it in your truck and see if it quiets down. Mine does, but then maybe you don't have a supercharger and/or your tone deaf. I think you just have SuperCharger envy!
Don't judge others for something you know nothing about or have not experienced!
Sick of Ass Clowns like you...exactly why I left this forum before.
df
Discussion Starter · #11 ·
If premium gas is making your truck run quieter, then you are probably pinging with low grade gas. With your charger i'm sure that's the case. No need to be callin names now.:dunno:
No it's not pinging sound. The actual exhaust tone has decreased with high octane fuel or better quality fuel.
I will to prove it.....hmmm maybe I can make an avi video file and post it...would need a sound pressure meter.
Anycase, I notice little things like the tone of my engine and exhaust, when my truck is soooooo sensitive to different gasoline mfg.; especially when we Kalifornia supercharger peeps have to put up with 91 octane crap.
df
df
I'm talking about cheap gas vs expensive gas....
Gas is gas...
NorcalPR,
If thats your belief, You just keep on believing that...in that case also, you should keep on buying the "Thrifty" Gas and see what happens to your valves and injectors.
I guess according to you, "Top Tier" rated gasoline means nothing.
No harm, No foul to me...I'll keep on doing what I'm doing and you do what you do....others will follow whoever. I have over 127,000 miles and have never had to correct an issue with Toyota or check engine light come on and I beat my truck like a redheaded step child!
Blah! df
Discussion Starter · #15 ·
higher octane fuel won't ignite as easily under pressure. with a supercharger your getting more compression. shitty gas pre ignites like a son of a bitch with high compression. If you like your heads, then continue using the "good" gas.
Now that you removed the mufflers from the intake, the intake noise is now complimentary in tone to the exhaust noise. Since low frequency sounds are increasingly non-directional, it is tough to tell whether the extra noise is coming from the front or rear.
Discussion Starter · #17 ·
sounds like you paid attention in science class. I shoulda done the same.
first off hight octane is a hell of alot better then low octane worse case scenario with low octane bent rods bad yes i learned this in my mechanics class higher octance ignites alot better and burns better
First of all lower octane ignites more readily and is the reason higher octane ratings are required for higher compression applications. It doesn't burn any better or cleaner than lower octane gasoline it just ignites at a higher temperature giving the engine a chance to burn the fuel in a controlled manner rather than detonating in an uncontrolled and engine damaging fashion.
Maybe you should seek a refund for what ever you paid for your mechanics class. If this message is any indication, I would also say that that perhaps you are due a refund for your English instruction.
I took off the long ass tube running from the air filter housing to the front of my truck into the silencer on my 22R and it makes it sounds NEAT-O! But deffinatly not louder through the muffler... :2cents:
1 - 20 of 38 Posts
