1 - 9 of 9 Posts
i have a 97 tacoma xtended cab 4 cyl 5 speed. i want to run 33x12.50x15.
on 10" wheels. is there any certain spacing i need for the wheels and will this lift be enough. all help is appreciated.
I too would like to know. As far as I have read, you can only fit 33x10.5x15 with only a 3" spacer or coilover lift. Most have said that you need to add a 1"-3" body lift on top of the 3" suspension lift to fit 33x12.5x15, especially with 10" wide wheels.
I ran the revtek and 33x12.5s on an 8 inch rim for awhile. It rubs with out pinch weld trimming for sure. 10 inch wide rim wont work for you. I would go with a one inch BL too. I did and it only rubs when its flexed out
Brian
Brian
Same Here....same setup for a whille.
Dont go 10 inch or you'll rub like crazy
1 - 9 of 9 Posts
