1 - 11 of 11 Posts
It's an '07, has about 1,600 miles on it and I noticed this recently, should I take it to the dealer to have it looked at or is this how everyone's is? It just seems like Toyota would finish the pruduct better than that and not have all those bare wires exposed to the outside.
what am i looking @?
The chrome tip on the exhaust or the too small shutters on the house?
not sure but i think that looks like a dealer installed option plug. Might want to take it back to the dealer or wrap it with some electrical tape.... which is what they are going to do most likely. Don't think it came from toyota like that. just my :2cents:
if everything works right, you might want to buy a can of spray cleaner, for electronics
(just to remove moisture, if you want to be anal) then slide the plastic wire cover to the plug and black tape away.... the poster above was right that the dealer is just going to do what you could in less than 5 min.
The bracket got bent upwards, that is why the wires are exposed...
ok..it sits low and you snagged it on something during your first 1,600 miles. better that it bent a little than getting ripped off like a lot of people. Check out the thread in post #5. Most people will choose to relocate it. I drilled a 2 & 1/8" hole next to my license plate so it is up and out of the way. A lot of folks will remove one of the license plates lights and put the trailer plug up there. Easy fix....
1 - 11 of 11 Posts
