1 - 20 of 30 Posts
Hoist The Colors!
January's item to be given away has been donated by Marlin Crawler. They have generously donated their newest addition to their 4-cylinder Tacoma/T100 product line: a world’s-first 2/3RZ to R-series transmission bell housing!
Marlin Czajkowski has developed a new bell housing for all 2RZ-FE or 3RZ-FE powered Tacoma/T100 pickups that will allow either a R151F (1986-87 Turbo 4cyl 5-speed), early R150F (1988-95 3.0l 5-speed), or late R150F (1996-04 3.4l 5-speed) transmission to be bolted directly up to the 2.4l or 2.7l “RZ” engine block.
The R-series transmission is much stronger than the factory equipped W59 transmissions used in 4-cylinder Tacoma’s and T100’s, and utilizes a true 23-spline transfercase. The R-series transmission features larger internal components and do not suffer from the inherent problems of the W-series transmissions, such as a weak 5th gear, main shaft bearings, and reverse gear.
This bell housing makes for an ideal choice for all “RZ”-powered Desert Racers and Rock Crawlers alike, who desire the strongest Pickup/4Runner/T100 manual transmission and 23-spline drivetrain. Vehicles that are converted from a 3VZ-E to a 3RZ-FE will especially appreciate this bell housing due to the fact that only very minor drivetrain modifications are required.
The winner will be drawn on January 15th. Remember, you must be a Contributing Member to be able to be eligible for the Monthly Give-A-Ways!
Thanks, and Good Luck!
Another great monthly give away from a great vendor. Thanks Marlin!
Thanks for the chance!
+1 to Marlin for the very generous contriution.
Old Timer
Cool! I need one of these! :welder:
1 - 20 of 30 Posts
