1 - 15 of 15 Posts
i have an 07 taco access cab 4x4 trd, whet is the largest size tire i can
put on the stock 16 inch rims with no rubbing issues?
thanks
thanks
the same size that's on there now...unless you lift it.
265/75/R16 might rub a little. Just stay stock until you get some lift.
245/75s come out to a 31x9.50
265/70s are 31x10.50
265/75s are a 32x10.50
I searched for hours and I dare anyone to find one post that says 265/75/16s WILL or WILL NOT fit an 05+ taco from someone who has the combo...
I did read about 100 posts with go search... If it that often requested, why not a sticky?
Hytenor says no, but no one with 265 75 16 have come forward who has tried with a stock suspension...
wslytoy says yes...
So yes or no, do 265 75 16s fit on 05+ 4x4s and prerunners ???
Heres the bottom line. The 265/75R16s will rub some. If you cant live with that then lift it 3" or less.
wslytoy says yes...
If it helps, Chris (Hytenor) is an experienced wheeler who knows a lot about Tacomas. Wes is a dumbass web wheeler who doesn't know shit.
Later,
....Mike
Later,
....Mike
hytenor helped me about 2 years ago with a question I had... HE is a great resource...
The reason I am asking, one, couldnt find an answer with the search option... two, couple hours of reading USE THE SEARCH feature gets old a couple hundred times...
I thought, but unsure, that when the 05's came out that they could up to 265 75 16 but cant find those threads....
hence, the question yet again...
1 - 15 of 15 Posts
