1 - 16 of 16 Posts
are you refering to the rack boot? that would most likely be a rack end seal leak and i belive it requires replacement or a rebuild.
Rack?
That rack is expensive. I would say rebuild it, but I have no idea how hard that is to do. Pop the outside of the boot off (clamp) and make sure it is leaking, some look that way from grease inside the boot, not oil.
Banned
Discussion Starter · #9 ·
Just FYI got it fixed If i didn't have the warranty they would have charged me almost $900 but got it all done for $50. They replaced the hole thing plus some gear?
why did it cost $50 if it was under warranty?
put a trans cooler in-line, you can get them through summit they are built by morosso.
You can get a TruCool (hayden) even cheaper......google TruCool
looks like it's leaking from the flux capacitor. :2cents:
1 - 16 of 16 Posts
