1 - 11 of 11 Posts
well I just noticed some grease build up on my CV's. right where the rubber boot meets the axle.....
it's only on the passangers side though and I wiped it away. there wasn't even a lot about as much as the amount of toothpaste you would put on your toothbrush.
anyways....my questions are A. am I ok? I know obviously it can't be a good thing but with the minimul amount that is coming out is it something I should be extremely concerned about. and B. whats the consequence of this leaky CV. what happens to my truck when my cv's are leaking (so I know what to look for).
thanks in advance
-Spence
Check your boot on that side you most likely have a rip or a worn spot in it. I have one on my truck that did the same thing I have manual hubs and I forgot to unlock them one day after playing in the mud and messed one of mine up.
I have seen them seep a little lube at that point; no big deal as long as it's just a little seep. However, like suggested, check the boot real good for any for any damage. This lube will not leak out through a small oriface, it is some incredible stuff. I had a torn boot for the last month; I had the replacment cv axle on hand but no time to change it. So after driving 75 miles a day in rainy weather for a month, on dirt roads, I expected it to be a scored up mess inside when I finally replaced it. I found that even with the boot completly ripped open there was still a large amount of lube in the joint. I tore it down, cleaned and inspected the joint and bearings and found no damage what so ever, not even a scratch. I am going to replace the boot with a high angle boot and keep it for a spare.
Just make sure you get high angle boots when you have them done. I just found out the hard way by having a new boot rip in less than 500 miles. Back to the shop for high angle boots. I only have the OME 881 coils as well so it wasn't that much angle on the boot. But I guess enough.
Dan
I managed to get 60k miles on my stock boots by cleaning the mud off of them after each adventure..................but will go with high angle boots next.
Dan
well - what the heck- I went with the 881s to try and avoid CV problems - They only give around 1.5" right? geez thats nothing....toyota has to stop making crappy and weak front ends.
man - my truck is a daily driver too...I better not be having cv problems every 500 miles
:mad:
Who sells these high angle boots my truck is a 95.5 tacoma I believe with the factory boots still on it. I was fine until I ran 80 on the interstate with the hubs locked in plus 8.5" of suspension lift didnt help. I'm glad I don't have auto hubs.
CV boots
Well Spence, what happens is every time you turn it'll squirt/seep more out till you eventually don't have enough and the joint starts wearing (prematurley). Just replace the boots/grease before this happens and you'll get many more miles out of em. It's not that hard to do. If your not familiar with how to do it, I have a write up HERE (it's posted on several individual TTORA State sites as well but this links to where it was originally writtten for) on how to do it.
Back in 1995'ish when Tacos were invented, we saw broken CV Boots on virgin rigs with 2500 original miles. Problem is the OE Boots are a thin thermoplastic hytrel material that dries out, then cracks prematurely. Downey has always offered the thicker softer polyurethane boots made by Empi. We don't know of a high angle Boot though. If you do, please enlighten me?????
Who is "WE"?
high angle boots are made by CV Unlimited. I think Downey calls their high angle. and Off road solutions make some too.
1 - 11 of 11 Posts
