taco23 said:
The LEDs probably won't be bright enough to have the same light output as the OEM bulbs so your gauges will be dim. Just my 2 cents.
You can get the inverted ones that spread the light a little better...but for the most part they spot. I did get the 74's for my AC cluster, and they are fine.
· Premium Member
jayotto4 said:
Nope this is for the 2005 with the LED ilumination for the guages.
There's no way possible that you will get that same effect then. You only have 4 bulbs behind your cluster, and you will get spotting. I'm assuming the 2005's have numerous LED's, kind of like the VW's do.
