Yes I see there is already a posting on "how to a rear diff " but since its called cheap tricks mine is cheaper! For the rear they give a toyota part number but you can actually use the stock breather just use a pair of pliers to remove the spring head thing " dont worry you can put it back together if you need to" go to auto parts store and get applicable hose and desired lenght use the hose clamp a lil bit or diff oil so it goes on smooth and shazaam its done, here the cool part since on the front with "IFS"the oil pan is so close to the top of the diff the original breather modification has to be used because of clearance issues. So altogether in my truck i bought 20' $3.75 of vaccum or fuel line just to be safe a pack of the small hose clamps $1.99 a Y connector $0.99 to join the two hoses and for kicks added a pure flow clear fule filter $10.99 ..... If you need them I can send you pics.
Aaron
Aaron
