1 - 16 of 16 Posts
Just about to home fab a rear bumper for my 4runner and just wanted to see bumpers that everyone else has made themselves. Show off your handy work!!:saw: :welder:
Not my handy work, but custom one-off!!!!
here's one a friend and I built...simple 2x6 tube cut up with a hitch welded all the way through and shackle mounts welded on. Runs C-channel straight into the frame (ID size of the frame rails) and is held in by a few grade 8 bolts.
Very nice, can we have more details on it? Great work.
I made it a little over a year ago. The tire carrier was a recent addition that got finished last month.
If you google "Brucets bumper" you will see where I got the design from. I based the bumper off his.
The main bar of the bumper is a 3/16 2x4 and the sides are all made out of 1/8. I'm using rockstomper D ring recovery points that are welded all the way through. The tire carrier is made out of 1.5x2.5 .120 wall square stock and its using a 1" grade 8 bolt with a dom sleeve and super oilite bushings.
i put my swing out carrier on the left side, seems to have better visabilty to the right side and behind me thru mirror, but with me and tire on same side truck leans a little, but i dont care about that:2cents:
The swing to the right side is kinda the standard in the US. The advantage is that if you are parked on the side of the road or if you get a flat on the freeway you can swing the tire out away from traffic. I get ok visibility with it on that side but at some point I will drop the tire down about 3" to get more visibility over the top of it. I did a little mis-measuring when I built it.
1 - 16 of 16 Posts
