1 - 20 of 22 Posts
Does anybody know of any companies that they would recommend for some slotted and cross drilled rotors..
Performance brake pads?
I only have 20% of my pads left..some this needs to happen..and soon..
Any websites or companies that will give a TTORA discount?
Thanks guys!!
IMO go with stock replacement parts. Aftermarket stuff isn't worth it unless you are racing the truck. :2cents:
Couple guys on Toyotanation upgraded their brakes.
EBC Dimpled rotors and Hawk Ceramic pads/Hawk Ferra-Carbon pads
They said they noticed a big difference.
Yeah, and I'm sure they did a controlled 60-0 braking test prior to installing and just after the install...right? Anyone who spends a large amount of cash on any upgrade will always tell you how great it is, cause they can't admit that they pissed away cash. Not to say that the aftermarket brakes aren't any good, just saying that the typical bang for your buck just isn't there, for the amount of cash spent. Just my .002
Thats true
I haven't done anything to my Tacoma's brakes...
But I've done it to lots of other stuff.
While better stopping performance can surely be had by changing the pad material, it almost always happens at the expense of pad life/durability.
Very much like tires, a soft brake pad "Bites" better and wears out sooner.
Again, I have not used the hawk pads on a Tacoma.
But I really wish somebody would take a set off road and dunk them in some muddy water so we could find out what happens.
I suspect that they will be worn out shortly after the dunking.
They might not even make it home.
For what it's worth, the factory pads seem to shrug off a dunking with little ill effect.
X2 Frank. Forgot about the water/mud issue. It's been a long time since I have done any muddin. Good point.
I agree!
The tacoma brakes are somewhat lacking..... I highly doubt that new fangled rotors/pads will make much (or any) of a difference.
The problem lies in the pedal travel... You have to step on the pedal soooo far to get a serious braking. It's almost like they're not proportioned properly OR the master cylinder doesn't have a big enough bore (or ABS systematics thrown in...who knows).
Acura vehicles are similar as Toyotas...
We own an Acura MDX - and the braking is awesome!! One little press on the pedal and you know its working. Press a little harder and you'll nearly go through the windshield. But then again..... 4 wheel discs.
Why can't the tacomas have 4 wheel discs by now??
I don't have any issues with my brakes. The brake assist took a while to get used to, but it works fine IMO. The brakes really come on strong when you get in a pinch.
EBC makes truck specific brake pads. Look at the green stuff line. They also carry a long life pad designed for freight trucks.
Slotted/drilled/dimpled rotors are a bad idea on a street car as they can make your brakes less effective depending on the pad choice. On a race car, they vent off gases built up under high speed high heat situations. On a street car, they prevent the pads from reaching the correct temperature.
If you HAVE to have the bling... get slotted only. they are cheaper, help slough out water, and do not significantly reduce the life of the rotor like drilled can.
a guy on the expedition portal swapped tundra brakes onto his tacoma. Cool mod imo.
FWIW - unless your racing your Taco, I would say go back with OEM stuff, or if you want to go with new aftermarket stuff, I'd say just go with trusted Brembo blank rotors, and some OEM pads.
I have seen the Tundra swap done, I think its a cool deal, but even there, you would run Brembo tundra rotors, with OEM pads.... just a thought.
the ebc will offer improved braking but at the expense of longevity. The trade off for improved stopping power is to sacrifice either the rotor or the pad. When i put them on my daily driver I went from 40k stocker pads to 30k EBC green stuff pads. No biggie for the improvement they offered. Others claimed 10k-15k life. EBC's customer service is great.. call em and ask them. they wont feed you bull just to sell expensive rotors you dont need.
What i want to see is a bracket that allows the stock tacoma caliper to be used with the stock tundra rotor. Moving the existing caliper further out on a bigger disk will increase braking power with out having to buy tundra calipers.
Interesting idea, probably worth looking into. Only issue: how would they interact with the ABS and brake assist system? In all honesty, I have never felt the need for increased braking capability, but if you wanted to run 35's, then I could see the benefit of the larger rotor. :2cents:
shouldnt be an issue since the abs reads wheel speed at the hub on a toothed gear. It compares one wheel speed to every other other wheel's speed looking for rapid deceleration.
ABS function would be the same.
The only reason I would like more braking is because I haul a trailer regularly. A pad or other simple upgrade is cheaper than a trailer with brakes :D Braking on the tacoma is pretty poor when compared to my other vehicles.
10-4 I get it. My personal experience has been in favor of trailer brakes. They are well worth the money. But if they aren't in your budget, then maybe upgraded brakes are the better deal. The first Q I would ask yourself is: how often do you tow and is this really worth it. If you tow a lot, then trailer brakes are worth it. They come in kit form, so you can do the work and save a bit of cash. My .002
I love my OEM brakes, they arent sqishy, and are very responsive, even with a bed/cab full of stuff. The ABS has never overreacted.
As far as towing, thats an easy one.. trailer brakes.. most axles have the holes to mount them to, and for a couple hundy you have trailer brakes.... about the same as upgrading the brakes on your taco, and much more effective.
I agree, why mess with a good thing, when trailer brakes are an easy upgrade:confused: They just aren't as cool :cool: as hot shot brakes on your new truck :) We all gotta learn the hard way, so I'm stepping out of the way.....:)
Crossed drilled rotors are also more prone to warping and cracking. For sports cars, they may look "cooler", but they're not as effective. Slotted rotors are more effective in keeping the pads clean in racing applications.
1 - 20 of 22 Posts
