Maybe worth a sticky....
I'm thinking it would be good to have one place to lookup information about the different lift kits for our Tacomas. I just finished installing the Tuff Country 5in on my '99 and had some feedback, both good and bad.
Good first:
Very solid components
Single piece sub frame is very stout
New Spindles with bearings already in
Very stout diff drop brackets
The ride is great
Negatives:
Holes don't line up between diff drop and sub frame.
Rack and pinion mounting holes don't line up, center one is
off by half a hole.
Rear is lifted only 4in.
No extension or surface for the bump stops in front. I sent an email about this because I feel this is a very bad design flaw and here is the response I got:
"You are not missing anything. Tuff Country feels that with the new strut spacer attached to the stock strut, that there is no reason to incorporate any lower bump stops. The spring rate on the coil spring will not allow for the shock to compress it self completely and the strut acts as a limiting strap. If the shock was to be compressed completely, then Tuff Country feels that the vehicle is abused. "
UM, Abused? Not hardly. I've hit the bump stops on potholes in the road let alone offroad. Toyota put them in for a reason.
Had I known that before buying the kit, I may have gone with something else. I will definately be getting something in place for the bumpstops because bottoming out the shocks will (IMO) destroy them before too long.
Hope this helps somebody decide on which kit to get.
Erik
Good first:
The ride is great
Negatives:
off by half a hole.
Erik
