1 - 20 of 45 Posts
I have a question for everyone. Im planning on getting a lift kit probablly next spring or this summer. What ones are reallly good for their worth and wont break easily? I was thinking a old man emu(is that right?) one for 1K.
I probablly wont do alot of MAJOR rock crawling and such. Maybe small ones but I unno. I want a 2-3 inch lift but I dont think I will go over that. I also am saving up for new bigger tires. Also what tires are better to get?
Ideas please?
(yes I am female, mechanically retarded, and have no idea about trucks or vehicles. hence why I am asking. Please no sexist comments..)
The cheap/ Quick and dirty way to lift your rig is either a body kit or coilover spacers and add a leafs.
The expensive / right way to do it is to replace your coil overs and rear leafs.
But the big thing you need to ask yourself is what size tire do you plan to run?
I would rather spend the extra money knowing I got a good lift that won't break.
and I have no idea what the difference is between tires.. .-. I dont even know what tires I have on my truck.. and I need new ones now..
how do you tell what the tire is (i can figure out the brand) but like.. how do you tell the size of the tires?
The size of your tires will be marked someplace on the sidewall of your tires.
It will say something in the line of 265/75R16 (Metric) or 31x10.50R15 (Standard).
There are lots of tire size calculators on line that can help convert what size the metric tires are to standard. Just so you get a better idea of how big your tires are.
#1 cruiser
Old man emu is a good brand. Hardly ever hear bad bout those products. Total chaos I hear is also good. Stay away from fabtech. In my opinion. Tires you prob won't want bigger than a 33. Tires in that size will b cheaper and will get you thru almost where ever you want. As ur not going for rock crawler those will do well. I would also aim at an all terrain over a mud terrain. Look at Goodyear's or bfg. Again all my opinions.
I'd second the OME (Old Man Emu) lifts. They are also reasonably priced. As well as going with 33" All-Terrain tires.
Before I went crazy with my 88 Pickup, I was going to lift my Taco.
I went with ToyTec adjustable Coilovers, and was going to get some Alcan rear leafs.
I was also going to go with 33x10.50r15 tires or 285/75R16.
I wanted the narrower tire because they give better traction in the rocks.
Old man emu is a good brand. Hardly ever hear bad bout those products. Total chaos I hear is also good. Stay away from fabtech. In my opinion. Tires you prob won't want bigger than a 33. Tires in that size will be cheaper and will get you through almost where ever you want. As ur not going for rock crawler those will do well. I would also aim at an all terrain over a mud terrain. Look at Goodyear's or bfg. Again all my opinions.
What about Firestone? We got tires from them before and they seemed decent. Then again I have no idea about tires.. haha. What about all season weather tires? I had them on my Subaru and loved them since I didnt have to switch out my tires once winter hit. Do they sell those for Tacos in bigger sizes?
I heard Fabtech was good then bad.. Guess it depends on the tires.. My friend said he got the jeep version of OME and loved it. So thats my top pick at the moment until I can find something else that would be better. I figured out the price and all and so far it will cost me $2K for the lift kit, tires and alignment and such. then again.. I need an alignment and tire rotation now really bad.. poor taco.. I abuse it so..
Do they? I thought that thicker tires would have more traction. hmm...
i gotta ask. (retarded moment) What in the hell are coil covers and what do they do? DCpsychobilly said I could have his and I have no idea what they do.. or are.
The wider tires have better floatation in mud and sand. That is the advantage of the wider tires.
No worries, I was once truck part illiterate too. ;) In fact there are still some parts that I have to look up in the service manual to find out what they are.
Coilovers are part of your front suspension. They are composed of a spring and a shock and mounting points.
If you look behind your front tire in the wheelwell you will see the spring, and the shock is surrounded by the spring.
Discussion Starter #10
oooh ok. ;P dumb moment. haha. I know very little and hate asking since it makes me look dumb, but hey. Gotta learn somehow. haha.
Agreed. Hopefully you get the patient people to answer your questions and not the impatient one who will go off on ya. Then tell you to use the search function.
Which is a good tool, once you learn how to use it.
EDIT:
Oh, and if you are looking for a place that sells OME kits you can try ToyTec Lifts right here in Northglenn, CO.
Moderator
Old man emu is the best bang for your buck on quality parts.
I would look into sliders first though so that the body of the rig is protected. Wheel it and then decide if you really want to lift it.
So, if you're visually oriented like me when it comes to vehicles, this might help illustrate:
Leaf springs on the rear axel:
Vs. Coil-overs on the front:
Here you can see both in action:
Not trying to be a dick, but I'm going to reiterate this:
Yeah, there's a lot of info there, but it's a good starting point.
As for tires, x2 on figuring out what you have right now, and then deciding if you want to change the size. Once you have a size in mind, http://www.tirerack.com/ might be a good place to start, you can punch in the size and see a ton of options (not everything possible, but a good selection).
Discussion Starter #15
I already have that thread bookmarked. Im using it as a guide, but knowing my dumbass i'll mess something up. haha. Hence why i'm asking and such.
Discussion Starter #16
Good point Ike,
Armor is a good thing, don't forget about skid plates too.
Ya, im looking into those as well. Gotta google what they are and look like. haha.
#1 cruiser
What is stock on those tacos. 260 70? Or is it 265 75? Sliders are a great choice for a first step. But if ur not really wheeling and more for show then the lift is ok to do first. Firestone is fine as far as tires. An all season tire is just going to be a road tire not an offroad tire. Not to say they can't go off road, just that you would want a more aggressive tread for offroad.
Imo get sliders to protect your truck first, "skids" keep the stock ones till you beat those up (I got lucky and got some hd skids for cheap), lift till your sure of what you want, keep in mind bigger tires will give you better clearance. I offered you a stock set of coilovers incase you wanted to put a lift (spacers, ome springs etc etc) you can get those modified with w/e lift you add at a shop or get some help (your truck will be driveable meanwhile) then with basic tools switch out the modded coilovers for your stock ones (imo it might/can save you time money and no down time of your truck) again its my opinion lol. Lmk I'm no genius but can explain stuff lol
Something to keep In mind, sliders/skids/bumpers = weight, a 2-3 In lift wont remain at 2-3 in after mods.
And If any of my info is wrong correct me please
x3 on armor. I have the Budbuilt full skid for my DC Taco and it's solid! No matter how much lift or tires, armor preserves your ride and keeps the breakage to a minimum! heavy skids and sliders are the way to go. I was wheeling with Ike a while back and avoided a LOT of area due to the potential of damaging my rocker panels. My Taco is a daily driver and I want to keep it looking nice.
Also, you can wheel all you want with stock tires/armor and lockers. The tires get you there, the armor slips you past the nasty stuff, and the lockers will make sure that if only one tire is on the ground, you still get to move.
That said, a lift and larger tires just make the trail that much easier. Armor and lockers both protect you and get you there. The lift puts your wheels down on the ground and give you the opportunity to get traction around obstacles.
I have a 6" fabtech lift with 35" BFG's and maybe 12" of clearance at the rear diff. My Tacoma does not articulate like Yanman's because his is great lift, while the fabtech uses bocks on the rear axle which does nothing to increase articulation.
My Unimog has 46" XML's and 22" of clearance at the rear diff. I have front and rear lockers and have no armor yet. My fuel tank might get dinged, but it's 30" off the ground. You gotta protect that tank if yours is low, and a lift helps with that.
Bryan
1 - 20 of 45 Posts
