1 - 3 of 3 Posts
I am looking to lift my 99 Tacoma prerunner an was wondering about how much lift i would need to fit 33'' BFG M/Ts on it. Does anyone know?
-AJ
donahoe coilovers, TC UCA, check demellos website or look for hoerunner he's selling his set...
When I got my truck it had a 3 inch Body lift and 33's, they rubbed at full turn but when I put new shocks on and did the pinch weld mod they stopped rubbing. I believe the usual consensus is 3 inches of lift to clear 33's without doing a lot of cutting in the wheel well. Since you have a prerunner you can crank the front up 3 inches with a front suspension lift to clear the tires and not have to worry about your CV's like us 4x4 guys do. Add a Leafs or blocks or new springs are the options for the rear lift.
There are a lot of threads about lifting prerunners, look in the Prerunner tech folder and do some searching and you will be able to find what will work best for you.
1 - 3 of 3 Posts
