1 - 3 of 3 Posts
i have a 2000 sr5 3.4 v6 and i grabbed tundra coil overs and with a little force i put them and it gave me a natural 3in lift. i put shakles in the back and im wondering if i could put more of a lift on but cheap. i wanna run bigger tires (im thinkin 33) with out rubbing and i dont have a lot of money im still in highschool. cheaper the better, i hit trails and mud if that helps thanks guys!
Unless you install a drop bracket kit like the Fabtech or Trailmaster or similar, your next option (and considerably less expensive) is to install a body lift.
If you really want cheap go with a coilover spacers for the Tundra coilover (since that is what you have) and blocks in the rear... not the ideal set up but it will give you more lift to fit your desired tire size... Try Revtek, Daystar, etc :)
1 - 3 of 3 Posts
