Hey there guys, I'm new here and would like to see what you think of the lift i'm planning on doing. I did alot of searching on here, and came up with these Items. I really wanted more than 3" of lift, but after searching I found out that any more than 3" you are going to have to cut things on your frame, and its a major ordeal to install. So I'm basically going to go with 3" coil spacers on the front, and 3" AAL's on the back. Also the kit im getting comes with front diff drop. Here is a link to the kit.
http://cgi.ebay.com/ebaymotors/ws/e...ry=33585&item=7939042328&rd=1&ssPageName=WDVW
Now once I get this I am under the impression that you don't need to upgrade your front shocks, but you do your rears. So I came up with the Bilstein 5100's. Item # BE5-6253-H5
And last but not least, once I have my lift I'm pretty sure the biggest tire I can fit is a 285-75-16. With the correct offset on the wheels.
If you don't mind please!!! give me your opinions on this. Is this the way to go? Is there a lift out there that offers more than 3" of lift that doesn't require cutting anything, or isn't that big of a deal to install? Instead of getting coil spacers should I go with an entire front coil setup from like fabtech or someone else? Thanks I greatly appreciate your opinions. And I'm glad to be on this forum!!!
