1 - 11 of 11 Posts
without getting bigger tires, or using after market shocks, what can i buy to just simply lift my truck and where can i find it? ok, i drive an '03 pre-runner 4x2. i can use a spacer kit along with aftermarket suspension though, right?
I you aren't into serious off roading I would think a spacer kit would be best. Just lifts the body of the truck from the frame allowing for more tire clearance but doesn't require new suspension components (that I know of...) check out Revtek's lifts
PS - list what your truck is, this will help people direct you where to go.
yep, you sound like a spacer kinda guy... revtec, toytec take your pick....
when you say "spacer" lift, I assume you are talking about body lifts right that don't mess with the actual suspension of the truck? typically, "spacer" lift is an inexpensive lift that places a polyurethane or aluminum spacer in or on the coilover, therefore lifting the suspension of the truck. just trying to clear up any confusion (at least i'm confused :confused: ) about what exactly you are trying to accomplish.
1) body lift and no suspension mods?
or
2) mild spacer lift that wouldn't lift your truck much and still allow you to retain stock tires and, if you wanted to skate by, rear shocks?
maybe i'm the only one who isn't real clear on the question......
spacer lift Joel! DAMN... haha, you still awake over there.... lets go hit some bars before they close...
a spacer lift huh West? :D sounds like confusion between body and suspension lifts to me....
oh, and bars tonight? ;)
nah, just sounds like City_Rider is confused.... its either a RevTec spacer... or a body lift. RevTec doesn't make em, that i know of.
After the bond fire tonight, i'm down for some bar hoppin.
spacer lift goes on top of the coilover which causes the suspension to droop to bring up right height. body lift is installed on body mounts and does not have anything to due with your suspension. spacer lift > body lift
Thanks for clearing that up - for this one I was confused.
I was thinking of a spacer lift (such as Revteks) not a body lift. Bad wording on my behalf - Sorry for the confusion!
its cool, happens to us all at least once... then we never F-Up agian... ;)
1 - 11 of 11 Posts
