Where is the cheapest place to buy them? I tried the 24 hour autozone off of 59, and found nothing
Which one did you go to?grillmasterp said:IIRC- The bulbs behind my AC/Heater control panel as well as my glove compartment light used style #74
- It was available from my local autozone
I think I went to the Autozone @ Westpark & Fondren-NisAznMonk said:Which one did you go to?
Are these the lights I need for my 2001 DC?Icepuck72 said:If you want LED's, I got mine from www.autolumination.com
I purchased the blue ones, and they look great.
You need the #74 lights....2 of them....for your AC cluster...for your instrument panel, you need the #194's....4 of them to be exact.NisAznMonk said:
which style did you get? did you get the inverted lense ones or the regulars? just curious as to how your light pattern is on the pannel with whichever you got.Icepuck72 said:If you want LED's, I got mine from www.autolumination.com
I bought some LED's from superbrightleds.com and the ones I got...the smaller led's in the clusters started to burn out. These were for my parking lights, license plate lights and third brake light. I emailed them and they were like tough luck..jjrambo said:which style did you get? did you get the inverted lense ones or the regulars? just curious as to how your light pattern is on the pannel with whichever you got.
autolumination is the other place i was trying to remember that has them. they also have a sister site, I'd have to look back on to customtacos.com to find it. I recently posted a lengthy deal on the whole LED stuff on there.Icepuck72 said:I bought some LED's from superbrightleds.com and the ones I got...the smaller led's in the clusters started to burn out. These were for my parking lights, license plate lights and third brake light. I emailed them and they were like tough luck..
SO...I went to autolumination and got the same LED's for the same set up and I've had them for a year now...they're working just fine.
My 3 AC control light bulbs look like these.NisAznMonk said:
Those look like the #74 LEDs your speedo lights should be 194 bulbsNisAznMonk said:My 3 AC control light bulbs look like these.
Are these the ones I need? I plan on getting the superwhite.
You should only need 2 for your AC cluster....NisAznMonk said:My 3 AC control light bulbs look like these.
I thought there were 3, but i'll double check anyways. Thanks!Icepuck72 said:You should only need 2 for your AC cluster....
Like I said earlier...if you have a '01 and up...you have that orange film behind your stuff..
