Have had my SAWs on for quite some time and still have a question. I have them cranked where 3" of thread is showing, is this too much to achieve 3" of lift?
Do you have a baseline measurement of any kind from the before and after lift??? Without it, you are never going to know the answer. Maybe someone with a SAW setup can give you a measurement from the center of the axle to the top of the fender, ans a measurement of the threads showing on the coilover. Other than that, the great OZ hasn't spoken, so Dorothy don't know..... :xdevil:themariachi said:Have had my SAWs on for quite some time and still have a question. I have them cranked where 3" of thread is showing, is this too much to achieve 3" of lift?
turns out not, i have a full 3" of thread showing04RedLobster said:i thought they can be only cranked up to 2"...
i know camburg is 2.5"
the pain is i don't have that measurement...when all my lift stuff came in, i got overly excited and got to work. do you, or anyone else, have SAW 2.0s with 3" of lift for sure? A measurement of exposed thread would help answer this.rojodiablo said:Do you have a baseline measurement of any kind from the before and after lift??? Without it, you are never going to know the answer. Maybe someone with a SAW setup can give you a measurement from the center of the axle to the top of the fender, ans a measurement of the threads showing on the coilover. Other than that, the great OZ hasn't spoken, so Dorothy don't know..... :xdevil:
bottom of plastic fender? not too sure what that is...fender flare, inner fender? another problem with that type of measurement is that i have different sized tires, so the measurement wouldn't indicate total cranked lift. do you know how much thread is exposed to give 3" of lift.atwinda said:you can crank them as much thread is there, but it's not advised. 36" is stock I believe, from bottom of plastic fender to ground. So that should give you some indication of where you are at.
yeah, up to 3", but i don't think they really recomend higher than 2.5", but the diff drop helped with the CV angle and down travel.04RedLobster said:oh so do you mean you can extend them up to like 3" on the SAW 2.0...? when they mean like 2.0..was that like it's good up to 2" or something like that?...i never knew u can crank it up to 3"...
do you know the minimum amount of thread that is exposed to achieve 3" of lift? I need to find out before something bad happens to the ol' CV boots.Harryarse said:I believe the 2.0 SAW refers to the shock diameter size and you can probably crank them up over 3" but it's recomended that you don't crank them up past 2.5", especially if you have ADD set-up.
How exactly do you think the diff drop affected your down travel?themariachi said:yeah, up to 3", but i don't think they really recomend higher than 2.5", but the diff drop helped with the CV angle and down travel.
SAWS use a 2" diameter shock body, Kings, Donahoes, and Camburgs use a 2.5" shock body. More volume for oil means less shock fade when they're being punished.04RedLobster said:oh so do you mean you can extend them up to like 3" on the SAW 2.0...? when they mean like 2.0..was that like it's good up to 2" or something like that?...i never knew u can crank it up to 3"...
was that after the lift, because i just measured mine and it was a bit over 25"phand00 said:Maybe I can give you an answer. Mine is a 2k4 4wd TRD X-cab with V6 and with bilstein I got 21.5 ~ 22 from center of wheel to fender flares. So with this mesurement, you should know how much you get yours even with different size wheels! And sorry I can't tell how much thread is left... I have the Allpro - Bilstein setup!
Hope it helps
just did a remeasure, and it's about 25.5", man that doesn't sound good...themariachi said:was that after the lift, because i just measured mine and it was a bit over 25"
It looks like you received very good info from others who have lifted their trucks also. To answer your question, the amount of threads showing does not determine the exact lift in inches. For example on all of our test vehicles and other installs we have done, we have usually preloaded the shocks with about 1 3/4" D & 1 5/8" P for the offset of weight on the drivers side, from what I can remeber this gave us about 2.5" maybe a little more over stock. You can squeez about 3.5" of lift w/ a uniball upper arm, but just remeber the more you preload the spring the stiffer your ride becomes. I hope this also helps, as alwyas please feel free to email [email protected] for any questions or comments about the product we offer.themariachi said:Have had my SAWs on for quite some time and still have a question. I have them cranked where 3" of thread is showing, is this too much to achieve 3" of lift?
The 2.0 and 2.5 you're thinking of is the shock body diameter, and has nothing to do with how much lift the coilovers can give.04RedLobster said:i thought they can be only cranked up to 2"...
