My locker was not locking, so I removed the motor from the 3rd member, and took it apart. There was a lot of built up crud on the screw shaft that is connected to the motor. I cleaned it, regreased everything, and put it back together. Put it back on the truck, jacked up the back end, pushed the locker button, and it locked right away. I was stoked. Then I go to unlock it, and I here the motor go, and the light doesn't turn off. I figure it needs some pressure or something on it, so I take it off the jack and drive, turn, reverse, turn, 4lo, you name. light is still on. um... HELP!
Edit: I know it is indeed still locked cause I jacked up the tires again, and spun them.. they both spin the same way.
