1 - 20 of 27 Posts
So I'm lookin at my next purchase. and I'm stuck between getting gears or lockers. As for gears I was lookin at a set 4.88s. I got a 93ext. cab 5sp w/35s. I found some good deals for front and back w/master install kits for about 600 with tax. OR I could throw in some detroit lockers front and back. Just wanted some :2cents: on it. Thanks.
WAIT!
Get the gears and lockers at the same time. Otherwise you pay 2x if not 3x the labor....
It's worth it. But if you can't wait get the lockers first. Granted it will suck you dry on gas mileage but hell you'll be able to crawl better... :D
Big tars, little bed.
Get the gears... and a rear locker. Like mols said if you do em separate youll pay twice for labor. Get the gears and try and afford one locker at the same time :D
The gears will get you back in the ideal rpm range which will help you power and mileage and crawlability.
And at least one locker, rear first, will put you miles ahead of an open diff.
And FYI the labor is gonna run another $500 give or take on top of the $600 gears.
Unless you know someone.... :D
Know what ya mean. ;) Bad thing is, when they do it for free, sometimes you have to wait 3 months and they do it at their convenience. :rolleyes: Thats the boat Im in right now. :banghead:
Yes, I got stock gears w/35s and it sucks. So ill definetly go with the gears first. Im gonna install them myself. with a lil help:confused: should be a good time. Ill post some pics.
Gears in hand? Good. Wait until you can afford an ARB for the rear, then do it...leave the front open or save for a second ARB. You'll run the front open 99% of the time, but the spiders and carrier are much stronger than the OEMs.
I was thinking of going with detroit lockers. Ive heard alot of bad and good things about ARB. It seems to be 50/50. Any suggestions?
Yeah...get the quad seals if available for the part #s you need, run full pneumatic switches, and make sure someone competent sets up the seal carrier, air line and bulkhead. Make sure the air line is protected.
There's nothing wrong with a Detroit either...but around here, where it snows, it's nice to be able to choose.
-Sean
Well, that's a bit of overkill ... but indeed 99.999% of the problems with ARB's are installation related. Take time up front and avoid big issues down the road.
Personally, I would not run pneumatic switches - no way in hell do I want even a little bit of gear oil venting into my cab!
Not sure for a 93 so I might be incorrect, but I don't believe detroit makes a front locker for toyota's front axle, I know that is the case for the 01's-04's.
Not sure for a 93 so I might be incorrect, but I don't believe detroit makes a front locker for toyota's front axle, I know for the 01's-04's the main ones to choose from are lockrite, aussie locker and arb for the front. lockrites and aussie lockers you can install yourself if you want to do them at a different time than the gears. I am getting gears front and back and an aussie locker for the front installed this Friday and figure if the locker sucks in the snow, I'll bite the $230 dollars it cost me and save for an arb.
How thirds with 4.88s. I got a v6 third and a IFS front that I will be pulling very soon to replace with 5.29s and My sas. THat way the set up is done.
THE rear is welded.
So if you are running IFS, you do not have a choice for Detroit in the front. I like my rear Detroit (well liked) it in Tippy (when she ran).
Please note that the Aussie or Lockright in the front (down the road) those are considered "lunchbox lockers" and ask 00RegCab (Nate) about it. He wheels hard. But any time we have to get up to speed he has to stop and unlock his front hubs (You will need to convert to selectable hubs too up front BTW).
Also you said you were planning to install the gears yourself? Have you done that before? If so :thumbs: if not... um, gears are something that really need to be set up right. Might want to have one of our local Toyota Tech's do it for you. It will cost but you need it done right! This the reason we say wait till you have that rear locker so you can have it all done at the same time otherwise you will pay x2... :(
unless you buy my junk...then it is all set up with the manual front axle :D
If I were to keep IFS, this is what I would do (I did, but now going SAS). I did have the manual hubs, but had to switch the front diff over to manual from auto hubs style diff. NOt hard to do , at all.
BTW, Toyota 8" 3rrds are easy to set up, but they do need to be done right. Or else they will work great for a little while, and then...
I've set up some of the dana 60s and 44s, and toyota 8" 3rds are a dream compared to those.
A lunchbox up front is a cheap, effective way to get your front end locked. And hey, it works. However, it is quite the annoyance that it is ALWAYS locked. Sometimes i get into tight spots where i have to pop the clutch a little and let the truck rock while i work the wheel over when i don't really NEED the front locker in such the spot. It would be more practical to just be able to switch it off. However, over time the people you get out with the most, and the 2-3 guys that spot you the most will get used to spotting your truck with it, and they know how to set you up to avoid such situations that you cannot see from the driver seat.
It's also a PITA around town in the winter, trying to get moving in 2wd with the rear locked is a hassle on icey roads and you won't have just normal 4wd. You have to be patient, and practice turning with the front locker on ice. As when you go for the initial turn in, the truck will keep trying to go straight and not actually turn. You actually have to throttle through the corner, which is completely opposite of what everyone has ever taught you.
if you're looking for 4:88's there were some that came direct from toyota (open) you can buy a used third and you won't have to worry about how it's set up....just slide it in. Then when you do have the $$$...slap the ARB into it. Selectable lockers seem like the way to go. :2cents:
get dual aussies....... little birdy told me that v6 aussie is coming out next week :D
1 - 20 of 27 Posts
