1 - 2 of 2 Posts
hey i just bought a lockright off of another member here and i was wondering how hard it is to install? i saw mikes install on his site but i wanted to get some opinions from others as well. i have never done anything like this before so i was curious to see if this would be an easy task? also is a vice a must to get the ring gear bolts off? any info or tips from you guys would be great thanks
A vice, a block of wood, and a hammer is a must. Also, get some white out if you don't have it. Mark the bolts as you take them off. (Clean the oil off first with some carb cleaner or similar) Also mark the ring gear so it goes back in the same spot.
It's easy. Use grease as a glue to hold the pieces together.
You don't need to remove the brake lines. Just remove the 4 bolts, and twist as you pull out. This will make the brake lines straight, and give you just enough room to slip the 3rd member out.
1 - 2 of 2 Posts
