1 - 8 of 8 Posts
So, since I pretty much have unlimited access to a SAS'd rig (Molly's), I think I should do LT on mine...
I've looked into the TC setups, seems like the Gen II Caddy is the way to go - don't see any reason to keep the torsion bars in there at this point.
Thoughts on the various TC setups?
Other manufacturers?
Key words to search on?
It will be for rockcrawling not hardcore desert use I would assume. You can't go wrong with Total Chaos. :2cents:
A little of both, but yes, primarily slower stuff. It will be my daily driver for the foreseeable future too.
Anyone talked/emailed Vendetta? I'm not in a huge rush if it would be worth the wait...
I am hoping Mike makes something for the 86-95 4x4 chassis. In a thread on DR he was saying the 2x4 kit, then 5 and 6 lug Tacos. Maybe if enough people bug him he'll do one soon. I am definitely interested if so...Otherwise I'll probably go Gen 3 TC.
Dude I know is getting the first 2x4 kit, very interested to see how it turns out.
i'd say go with TC, just because its modeled around a t100 CV, which will be a lot cheaper than going with another company that requires custom shafts to be made. also, if you break a custom shaft, you cant just go to napa or carquest or whatever and pick one up... with the t100 CV, you can. :2cents:
Discussion Starter · #7 ·
Thoughts on the rear? It's already coils and the gas tank has been relocated, so coilovers on a triangulated 4 link, or wishbone 3 link is very doable.
I could do leafs (63" Chevies, 62" Deavers, etc), but I would have to do extensive mods to the axle housing (cut off all the coil spring stuff, weld on leaf spring stuff).
Or I could switch to a T100 housing I guess to match the width in the front...
1 - 8 of 8 Posts
