1 - 3 of 3 Posts
Any suggestions to get some real travel out of my 96 4 runner out back? Any build ups out there?
Basically your main options are linking it or swapping over to leaf sprung.
If you want a little more travel to help match your front TCF susp. You can cut out the old mounts and put a bar across from one frame rail to the other. Then mount a short body coilover with an externar res to maximise the travel shock you can fit under there.
You should be able to get say.... 12 inches with a much better shock :saw:
1 - 3 of 3 Posts
