I went into my truck this morning to find out that my clock, radio, and power outlets are no longer working. I checked the fuses, both inside the cab and under the hood, and all are in working condition. What do I do next? Has anyone else had this problem? Its a 2001
Discussion Starter #2
I should also mention that the truck does start up, and everything else works just fine
STITCH - Come and Take it!
battery?... any noises when you try to turn her over?
Take a meter and check voltage on the battery.... should be over 12 vdc.
missed that second post that you stated the truck starts...
Since you have checked all the fuses inside and out....check the connection at your battery. Pull the clamp, clean the terminal, reconnect and see if it worked.
If not, then you will have to take a meter and start check for grounds and voltage, start with your radio and run a meter across the power wire to see if you are getting any voltage.
Also check your ignition wire, while you are at it.... have fun.
tracing electrical issues is a BEEOTCH!
