1 - 10 of 10 Posts
alright so heres the deal i got my truck really muddy last weekend and clogged the radiator full of mud so after it got really hot i pressure washed all the shit out of there and it ran at normal temp. the problem is though that whenever i get my truck running for a while it still sounds like its running hot and it gets terribly loud. any ideas on what it could be? any help is appreciated thanks ya'll in advance
You over temp'ed your rig. Chances are you already harmed the engine. Would recommend a computer engine check, compresion check and brain fratting?
You checked the air box and air filter I am assuming?
I'd say you've knocked something on the intake system loose. Check all connections and the air filter too. I've had mine so wet that it sucked it up the tube.
yes i checked the intake and everything put a new air filter in. checked the motor with the hood open and the engine running everything seems fine. its weird because it only does it sometimes its not like something constant that happens everytime i run my truck so thats why i think its weird. i dont know if you will know what i'm talking about but it sounds like my truck is running on about a 100 degree day but its running at normal temp and everything. thanks for everyones help so far
Discussion Starter · #10 ·
i'm going to try and wash out the radiator again tomorrow see if that does anything. its doing it on and off again now it will howl for a little bit then when i slow down and get on it again it quits its weird
1 - 10 of 10 Posts
