1 - 14 of 14 Posts
Hey everybody...
I know this isn't gonna make much sense to most of you but I am getting parts together for an sas and here's the part where I'll get Flamed prolly...
I wanna keep it spring under...
Be gentle...
the reason for this is I know that I like the low and wide look and I also know that spring under is said to be a more solid mount (or at least I was told so) Alot of rally trucks run spring under, and I intend to convert the rear as well...
(I'm also a slight tard and my friends and I like to hook 'em
up!)
My question is what size springs should I get to keep the ride height about 6-7 inches over stock?
I was thinking 7's and kinda building up the front hanger to hang a little lower to increase the height just a tad!
Input?
6 or 7 inches over stock is low???? :eek:
There are lot's of options to build a truck right and keep it low...........if it's going to see any rocks at all I wouldn't go spring under.
Poke around in the build threads here and on pirate in the older toy section...........you will find all the answers to your questions.
bc its what I want... It will be semi low in my opinion, considering I originally wanted 13. I dont want long travel at all... I want a strong solid front axle... and no rocks btw
Check out the truck on the left
TRDtacoma1985 said:
thanks agian tweeter.
Hes not peeing, he is reaching in his pocket. its an 85 i believe, that he got off of racedezert.com. it was owned by some socal shop that built it up.
specs-
straight axle front/rear
dual 12 or 14 inch bilstiens on the front
fully caged
fuel cell
2 full size spares
4 banger
light bar
both axles trussed with chromo
basically all the goodies for a small race truck.
i cant think of anything else at the moment.
1 - 14 of 14 Posts
