on my truck i have about 3 gallons of gas left when my light turns on. with my foot in it i get 10 mpg. so i can go 30 miles with my foot to the floor, 45 or so if i drive conservativelyEVOM1 said:How far can you Drive with the Low fuel indicator on? Driving conservatively.
My 99 has one. Might have been part of the SR5 package or with the V6 or something though.jtaco1 said:I guess Toyota didn't put them in 99's, although my parents 99 4 Runner has one.
I can probably get 36 more miles once the indicator lights up and stays lit.EVOM1 said:How far can you Drive with the Low fuel indicator on? Driving conservatively.
jtaco1 said:I don't have a low fuel light either, but once it is below the E I can go about 20 or so miles. I guess Toyota didn't put them in 99's, although my parents 99 4 Runner has one.
I've never had a low fuel light come on in my 2000. I guess a dashboard check in daylight will show if it's there. Once I left for work knowing it was low and it started stalling. I luckily coasted into a nearby gas station. We don't see no stink'n low fuel light.tbplus10 said:My 99 has one and my 98 had one also. Might've only been on certain packages, both my trucks were SR5's.
I've only seen it come on one time, I ran about 20 miles before filling up and had about 2 gals left in the tank.
Tim
I wouldn't push it past 40 miles. When my light comes on, I have 3 gallons left.EVOM1 said:How far can you Drive with the Low fuel indicator on? Driving conservatively.
Oddly enough my 2000 has neither a low fuel or low w/w fluid indicator.00Andy said:Oddly enough, I don't have a low fuel indicator. I have a low washer fluid indicator, but no low fuel indicator that I can find. But after the needle dips down below E where I usually fill it up, it still generally has 4 gallons in the tank. You do the math.
I've checked it in daylight and with a flashlight and I can't find anything. I've also had that happen where you start rounding corners and the truck sputters. Last time I ended up coasting into a parking lot - glad I keep a gas can with me!agroal said:I've never had a low fuel light come on in my 2000. I guess a dashboard check in daylight will show if it's there. Once I left for work knowing it was low and it started stalling. I luckily coasted into a nearby gas station. We don't see no stink'n low fuel light.
