so my carrier bearing is squealing like a mofo. would it be safe to make a small pinhole in the rubber part and inject some sort of grease or lube in there to shut it up? it sounds like the rubber part is squeaking more than a metal squeek.
it sounds like when you run your hand over a balloon or something.
i had the same problem on my truck and my bearing rotated itself inside the rubber. so u might want to take it out to see if it rotated itsefl off the rubber. and when u have it out might as well lube it the same time
cool i might pull the shaft tomorrow and check that out. thanx
Sounds like the bearing has probably tore away from the rubber boot. Call Shannon to get you a new one. 121.00
