No I am not clocked. (But I do have the 360 clocking adapter if that makes any difference...)NorCalPR said:
How old is your crawl box? I do not have a breather located on the shifter plate. Apparently the newer style ones have the breather built in to the shifter (as per Brendan at MC). There is "dead space" when I take the knob off the shifter (looks to be more like casting air bubbles rather than a breather though). Are you referring to a breather somewhere else? I am assuming by breather you mean similar to the one on top of the stock tranny shifter. Drilling some drain holes on the oil slinger sounds like an idea….wish I would have come here first. I just RTV’d it and put her back together. Seen a couple guys now post up about putting a breather on with no luck in solving the issue….
No I did not drain the tranny to install the crawl box. The tranny and crawl box do not share oil. However, the crawl box does leak into the dead space between the tranny and crawl box (where the transmission mount is). So be prepared for a mess if you take those 4 bolts out. Apparently this is to allow larger amounts of oil, as well as release some of the pressure build up. I have a 5-speed, not sure if it is any different on an auto or not.
