I love my twin stick, I use it all the time.dragr1 said:Who's got the Marlin Twin Stick on their Tacoma/4Runner and how do you like it?
Can you shift from 2wd low to 2wd high while moving?
Incidentally, I have a '99 4Runner 4wd V6 5speed.
Yeah, I didn't figure you could move from low to high while moving, but thought I would ask. Thought it might be a cheap way to gain take off power on steep hills pulling a heavy trailer.Mike said:I love my twin stick, I use it all the time.
You don't want to switch from low to high or vice versa while moving.
Later,
....Mike
Just trying to cover all the possibilities.Murderman said:I have twin stcks, but they are FROR, not Marlin; they are in an early gear case, not a Taco/late Runner gear case. Shifting from lo to hi while rolling can be accomplished with a little practice, particularly with a 5-speed where you can synchronize speeds better by downshifting the transmission simultaneously with the xfer upshift.
BTW, how many threads are you going to start related to your towing issues? I have counted at least five so far!
Murderman said:Just curious, you sig says that you have an '04 Z71, why aren't you using it to tow?
Yes, electric brakes would be in order and probably a sway control device also. This camper would be in the order of 3500-3700 pounds when loaded and pulled for a trip, so yes my 4Runner is a marginal tow vehicle for that amount of weight. As stated above I tow the camper when going offroading and also on other camping trips about 8-10 times a year. I can tow it with the Z-71, but that is a company vehicle-the boss lets me use it like it was my own, but when going on longer trips (over 100 miles) he prefers me to take my own vehicle b/c of liability issues-we don't do any business where I go camping and offroading (out of state) and also b/c I already put over 60,000 miles a year on it anyway.Murderman said:It would seem that a new clutch [the Centerforce in my FJ was absolutely killer!], and lower gears would both be in order then. They will also each help offroad, on top of towing.
Twin sticks are more useful for people with front auto lockers, not split shifting to tow with an arguable under-equipped rig. But, if changing gears, one might as well install the locker at the same time, and the twin sticks to go with it.![]()
Trailer brakes [I prefer electric because of the realtime adjustability] are most important for anything towing something that weighs more than a fraction of the truck itself.....particularly in the hills.
There's .04 for you...
AK98Taco said:Only problem I have had is the t-case staying in 4wd; it likes to pop out when bouncing on rocks, so I have to hold my hand on it.
Murderman said:Tow rig and trail rig are sort of mutually exclusive applications, but one would think the Runner could handle the 3,500#'s if properly equipped and maintained.
It's cheaper for me to regear and replace my clutch than to start all over with another vehicle. I already have the factory electric locker and for trails I do, I won't need a front locker. I have OME 891 rear springs and OME HD shocks-so the rear doesn't even squat to level with that trailer attached. I do have a Trailcarnage rear bumper-so I have to tow with an 8" drop hitch. You can see pics of it on my webshots page:Murderman said:I would suggest starting with electric trailer brakes and the sway control device that you already mentioned. Even if the Runner doesn't work out, they will be beneficial with whatever you use to tow it.
If the clutch smokes when you try to get rolling, it is probably in need of replacement. Centerforce is nice, because it gives more holding power without making the pedal pressure alot higher.
If it still seems to be struggling, shoot your wad on lower gears. Might as well throw in a locker or two while you are in the diffs. If you get a front auto locker, then get the twin sticks as well.
It is all about how much $$$ that you want to throw at the problem.
Just curious, do you use a weight distributing hitch, or have you beefed up the rear springs? It seems that most Runners are pretty soft in the ass end.
You are correct there.Murderman said:Sounds like a plan.
Don't forget the electric brakes; stopping is much more important than getting rolling.![]()
you got that right, with the f250 ive been using i would hate it with out the electic trailer brakes, but thats towing my 4600lbs truck on a 25ft gooseneck..Murderman said:Sounds like a plan.
LOL, I know the feeling of thinking you broke something because the front end isn't turning. I first discovered the problem coming out of the creek on Cliffhanger in Moab. Damn 2-foot ledge in front of one rear tire, other tire was climbing a 1-foot rock, and the front was pushing up another ledge. Couldn't figure out why I wasn't making it up, then somebody (not the spotterzszac111 said:Mine does the same damn thing, it only gets put in 4 wheel when i get to the obsticals, then i normally forget to put it in 4 wheel, the next thing i hear from everyone is (is his front end broke?) then i slap it down and go, but that bastard wont stay in half the time, hell maybe i focked up the install, dunno, but its no brain surgery.
