Yep, it's a classic question...
What is the max tire size I can run on a stock '05 Tundra Access Cab 4WD with NO rubbing on stock 16" steel wheels?
Willing to change to basic cheapo steel wheels (A.R., etc.) if a different backspacing is needed to clear a wider/larger tire. I don't need to go wider, just want to go a little taller.
This is not my wheeling rig. Have a thoroughly lifted/modded ' 95 Taco for that, so I just want to gain a wee bit of clearance on this Tundra.
Hook a brotha up!
TIA
Big tars, little bed.
Hook a brotha up!
TIA
Ill cut ya a lil bit of slack since there isnt much Tundra Tech here.
It would help if we knew your current tire size.
AFAIK 265/75/16 would be the biggest you could fit w/o a minimal lift unless you like cutting sheetmetal. I could be wrong though. I dont know how the others got 40's to fit. They rubbed like hell on mine :D
Meats
AFAIK 265/75/16 would be the biggest you could fit w/o a minimal lift unless you like cutting sheetmetal. I could be wrong though. :D
Thanks. 265/70/16's stock.
Cut enough sheetmetal on my Taco. Keeping this rig pretty stock. We'll save the rough stuff for the Taco. And the FJ...
