1 - 17 of 17 Posts
Hi all,
I was wondering if anybody could tell me what the max tire size i could go with a 3in lift?
thanks
Discussion Starter #6 (Edited)
Are you willing to cut your body mount for more clearance? If not, generally 32" tires is the biggest you can run before you need to shave the mount.
Ya I was thinking about doing 285/75r16. Which most are 32's
Sent from my iPhone using Tapatalk
Ya I was thinking about doing 285/75r16. Witch most are 32's
No, which most are considered 33" tires.
You need a 265/75-16 to be considered a 32" tire that will have little to zero contact on your body.
Check out BFG KM2's in a 255/85/16. I barely rubbed the frame at full lock on the street. Didn't touch the cab mount or anything else. With a 4 cylinder and 4.88's it was pretty well perfect.
depending on how much modding u do, I've seen a stock wrangler run 40" tires... with a little bit of cutting lol
Posted from Tacomaterritory.com App for Android
1 - 17 of 17 Posts
