I seem to remember reading about a Camry dual cam head swap awhile back on yotatech. You might check there. The only other thing I've seen is to completely swap it out for a 3.4 .tech96 said:What about a cam?
The Professor™ said:I seem to remember reading about a Camry dual cam head swap awhile back on yotatech. You might check there. The only other thing I've seen is to completely swap it out for a 3.4 .
tech96 said:I am about to change the motor in my 95 4Runner and want to try and squeze as much power as possible out of the 3.0. Is there anything to increase the power of the 3.0?
Whats a 3.4 going for? Maybe something to think about for the future.odonekanobe said:I have a 93 4runner that we just put a 2003 s/c 3.4. It's alot of work, but trust me, it's worth it. I can help you with info if you need it, but it sounds like you already have a motor.
In my opinion, the only thing the 3.0 is good for is a boat anchor. But I have see a few that put out some power...nothing like what you can do to a 3.4 though.
Hope this helps.
Eric
Thanks for the info on the heads. I will be pulling the heads off to check the cylinder walls and replacing the gaskets. I will look into getting them shaved by a local machine shop.akshunj said:If you're up for taking the motor apart, have the heads shaved down a little to bump up the compression. That will give you some more power. You could extrude hone the intake manifold. Add an intake, exhaust. It won't add up to too much in the end and you'll spend a lot of money.
If you really want power just put your own turbo kit together. I don't know if manifolds are available for the 3.0 so you might need to fab your own to go that route. The only reason I suggest turbo is because if you can swap your own engine you put your own turbo kit together. There's no better way for power.
Eric,I have a 93 4runner that we just put a 2003 s/c 3.4. It's alot of work, but trust me, it's worth it. I can help you with info if you need it, but it sounds like you already have a motor.
Hope this helps.
Eric
The guy that was trying to do that never got it done. It would be much easier to swap in a 5VZFE than to try to convert a 3VZE into a 3VZFE.I seem to remember reading about a Camry dual cam head swap awhile back on yotatech. You might check there. The only other thing I've seen is to completely swap it out for a 3.4 .
Eric,
I never have changed the motor yet and have been looking into the Ls400 v8 swap and have gathered alot of info to compare it with the 3.4 swap. I am currently researching the 3.4 swap so any info you could pass on would be appreciated. I am going to call my contact at the wrecking yard to price the 3.4 tomorrow. I have priced the v8 at $800 for everything but the size is my concern.
Bill
The headers are really the main part. I have to look into this further because the price I was quoted today on the 3.4 was a little steep. I have a 3" body lift because I am going to do the gas tank relocate so I think this will help on the motor side because I can raise it to clear the oil pan and from what I have read the factory headers.What about a the size on a 4.0 V8 concerns you? It'll fit and cool just fine.
Um maybe put a 4cyl in it...just kidding .The 3.0 is a guttless wonder and a POS in my opinion.I can't believe Toyota actually built an engine with no torque or horsepower and put it in a truck!I am about to change the motor in my 95 4Runner and want to try and squeze as much power as possible out of the 3.0. Is there anything to increase the power of the 3.0?
