1 - 20 of 23 Posts
Not sure what you would call this but ...
Im sitting in my '07 TRD sport today waiting in line at the car wash. I was playing with the buttons and found out that if you put the stereo in FM then hold down the "tune" button and the "text" button for a few seconds a menu comes up. You will see it say " SD 4 ".
press the " tune " button to scroll through the menu options and press
" < seek track > " button to change the selected option. for example the SD is set at 4 but goes up to 1000.
I couldnt figure out this menu so I left it alone.
Anyone know what the hell they do??
A cookie for anyone who figures it out...
Ps sorry if its a repost.
I'm not sure about the 2007 Tacomas, but for all 2006 Mazda 3s, there are a half dozen different little secret radio combinations that when pressed, unlock real-time MPG, average MPG, miles left on tank, and average speed displays.
It was intended so that you pay the dealer to unlock these things for you (for a price, of course) until this info was leaked a few weeks ago.
Your local dealer might have the info you're looking for. And for a measly $200.00, they might give it to you. :)
I dont think there are any options that im missing on my truck except the alarm but that is a wire thingy under the dash in '05 and prev. I think....
Has anyone gone and looked at this stuff im talkin about?
Bueller Bueller
On my audi you can do something similar and the different codes will display all sorts of info on the radio...from outside air temp, to a digital rpm readout, to all sorts of other things. Maybe toyota incorporated that into the new tacomas
I found a chart online that listed what each of the codes would display, you might be able to find one for the Tacoma but this is the first I've heard of it so I have no idea where you could look.
My 02 mustang has the same thing for the gauges, gives you all kinds of readouts. the digital rpm readout is cool but i have to program it everytime
I hope someone can find somthing im Google'in my arse off for it as we speak.
Plus I posted this at customtacos.com to see if any one there knows.
Discussion Starter · #9 · (Edited)
wrote down what it says on the stereo display.
what mode its in >> options
SD 4 >> 4 can be any number from 1 - 1000
DSEL ON >> ON or OFF
AD DATA >> AD DATA or SD DATA
AD 90 >> 90 can be any number from 10 - 500
ADLVL 53 >> starts at 1A through to 3A ect to 99
MinBW 120 >> 120 can be any number from 80 - 150
ADCN! >> cant change
VLVL 33 >> starts at 1A through to 3A ect to 99
VADLVL 53 >> starts at 1A through to 3A ect to 99
MU23 23 >>
MinMU 120 >> 120 can be any number from 80 - 150
Ver 0019 >> cant change
radio
Start diagnostic mode (All elements come on during
SW check mode).
(1)Turn off the audio system and turn the ignition
switch to the ACC position. While pressing the
preset switches 1ch and 6ch at the same time,
press the DISC switch 3 times.
(2)Reference:
• When the system enters diagnostic mode, a
beep sound is emitted 3 times and all the
elements come on during SW check mode.
• It takes approximately 40 seconds to
complete the check.
• Turn on all the elements in the LCD.
• When pressing the switch, confirm that a
beep sound is emitted.
(b) Service check screen.
(1)Press the SEEK TRACK UP switch to enter the
service check screen.
(2)In service check mode, the system check and
the diagnostic memory check are performed,
and the check results are displayed by
component codes in ascending order (physical
address).
Terms Description
Component code
(Physical address)
Three-digit code (in hexadecimal) given to each
device comprising AVC-LAN. Corresponding to
its function, individual symbol provided.
Logical address Two-digit code (in hexadecimal) given to each function and device unit in each device
comprising AVC-LAN.
AV
(c) Finish diagnostic mode.
(1)Press the DISC switch for 2 seconds or more, or
turn the ignition switch off.
(d) Service check mode result display (for checking the
current and the past system conditions).
(1)Press the SEEK TRACK UP/DOWN switch to
see the check result of each component.
Code No.
physical address Equipment Name
190 Radio receiver assembly (Audio head
unit)
440 Stereo component amplifier assembly
DTC CLEAR
(a) Clearing an individual DTC memory (when clearing
the memory of the DTC detected in the past
individually)
(1)Press the preset switch 5ch for 2 seconds or
more while ECHN is displayed in service check
mode or detailed information mode.
HINT:
• A beep sound is emitted once when the DTC
memory is completely cleared.
• When the DTC memory is cleared, only the
component code (physical address) is
displayed for the target component.
• To check DTCs, press the preset switch 1ch
and perform the service check again.
(b) Clearing all the DTC memories (when clearing all
the memories of DTCs detected in the past)
(1)Start diagnostic mode after repairing the trouble
area.
(2)Press the preset switch 5ch for 2 seconds or
more (CLR is displayed at this time).
HINT:
memories are completely cleared.
• When the DTC memories for all the
components are cleared, only the component
codes (physical address) are displayed.
(3)Press the preset switch 1ch to perform the
service check again, and check that no DTCs
are displayed for any component codes
(physical address).
(1)Press DISC for 2 seconds or more, or turn the
Discussion Starter · #12 ·
some info here ... but not much
http://www.tundrasolutions.com/foru...g/35150-2005-tacoma-stereo-test-tune-buttons/
Im finding that most of these menu's like ADCN! or VLVL are to do with voltage programming and Audio / digital codec's. MinBW is min band width for low frequency channels
After rackin my brain and having it melt it looks like toyota wanted somthing that could have a Bluetooth app put in later or some kind of memory ... either that or some Japanese guy did it to mess with us :D
Discussion Starter · #14 ·
what exactly does that do Jomentum?
Discussion Starter · #15 ·
Originally Posted by jrichardson20 @ customtacos.com
on this thread
http://www.customtacos.com/forum/showthread.php?t=85150
Just a shot in the dark, but perhaps one of them is to change the frequency range to European specs (i.e. radio stations move in increments of 0.05)(101.1, 101.15,101.2, ...). Does the HU run/connect to anything else? OEM amps, lights, etc?
That appears to be the self-diagnostic check for the audio system. I'm guessing AVC-LAN means audio/video control or center-local area network. The network bit would imply that the HU is set up to control other items, like a CD changer or TV tuner or something similar. The funny part is that in Jomentum's post, it only lists two components, the "190 Radio receiver assembly (Audio head
unit)" and "440 Stereo component amplifier assembly". Not much of a network... I'm guessing that the HU has the guts to control other items, as mentioned above, but its currently not implemented. Your last line, "Ver 0019", that can't be changed, is probably the software version number for the HU's "OS".
Discussion Starter · #17 ·
I concur... are there unused pre outs or any other connections on the factory Head Unit?
I couldn't tell you. I have an '02, and mine didn't have a stock stereo when I got it. But it doesn't mean that the connections would be there on the HU anyways. Many times manufacturers will use the same circuit board, but leave off the relevant chips and connections. So, the outputs could be there, but I doubt it. By not putting it on there, Toyota could save the cost of that connector for each truck made in '07.
Discussion Starter · #19 ·
Burp
1 - 20 of 23 Posts
