1 - 14 of 14 Posts
Ok. Sorry for any typos, etc. its been a long night. I bought some 5.29 gears and yukon master install kit for my non-trd tacoma rear. They got here and everything was peachy. Last night I take the rig to the guy who helps me with all of my gears and everything is going good until we realize there are no carrier shims or pinion shim in the master kit? wtf? Is this standard procedure or what? What are you guys doing that have regeared tacoma rear diffs? As of now im vehicle-less since the taco is my dd and i need to do something fast!
Josh
Retired
I bought two master install kits for my gear install and the shop didn't report being short on parts.
Every master kit I've seen has an assortment of shims. Not saying that it will have the right shims, but it certainly comes with them.
Its the odd'st shit ive ever seen. Its got a crap load of shims........just none of them are right. All of the bearings are right.......just the shims are fawked? Im lost here. Ive looked around at some other stuff and now im seeing that some peoples master installs dont come with all of the shims...........now is a time to find out.
Josh
Maybe you got a bad kit. Here's a little advice while you're in there though and if you have the time. Get rid of that fucking crush collar and replace it with a solid spacer. Marlin among others sell them.
Josh
The carrier shims are thick washers...dealer only.
The pinion bearing shim is also a thick washer and is hiding behind the inner race. It's a dealer item but some of the Dana 44 and 60 shims will work there also.
here's the carrier shim part numbers
mm inches Taco PN
2.58 .1016 90201-70064
2.60 .1024 90201-70065
2.62 .1031 90201-70066
2.64 .1039 90201-70067
2.66 .1047 90201-70068
2.68 .1055 90201-70069
2.70 .1063 90201-70070
2.72 .1071 90201-70071
2.74 .1079 90201-70072
2.76 .1087 90201-70073
2.78 .1094 90201-70074
2.80 .1102 90201-70075
2.82 .1110 90201-70076
2.84 .1118 90201-70077
2.86 .1126 90201-70078
2.88 .1134 90201-70079
2.90 .1142 90201-70080
2.92 .1150 90201-70081
2.94 .1157 90201-70082
2.96 .1165 90201-70083
2.98 .1173 90201-70084
3.00 .1181 90201-70085
3.02 .1189 90201-70086
3.04 .1197 90201-70087
3.06 .1205 90201-70088
3.08 .1213 90201-70089
3.10 .1220 90201-70090
3.12 .1228 90201-70091
3.14 .1236 90201-70092
3.16 .1244 90201-70093
3.18 .1252 90201-70094
3.20 .1260 90201-70095
3.22 .1268 90201-70096
3.24 .1276 90201-70097
3.26 .1283 90201-70098
3.28 .1291 90201-70099
3.30 .1299 90201-70100
3.32 .1307 90201-70101
3.34 .1315 90201-70102
3.36 .1323 90201-70103
3.38 .1331 90201-70104
3.40 .1339 90201-70105
3.42 .1346 90201-70106
3.44 .1354 90201-70107
3.46 .1362 90201-70108
3.48 .1370 90201-70109
I hate anyone with more and better tools than I have so that includes most folks.
You've got that right. My left handed monkey wrench (only works when I use with my right hand?), chinese socket set, cresent hammer, 24" water pump pliers, mexican speed wrench, duct tape, bailing wire and bubble gum seam inferier now?
PS: No disrespect to anyones heritage
1 - 14 of 14 Posts
