1 - 15 of 15 Posts
Does anyone have a a/f guage and obdII I could borrow to tune my urd kit?? Also, anyone with any experience with any of this, be willing to help me?
Thanks.
I'm retired from bothering with it...Jade Brink or Doug Gosh(TRDDoug) might chime in or be good sources to PM!
I recommend paying one of the performance shops I have posted links to previously doing it!
I highly recommend saving your initial Split Second tuning set up before starting...get it tuned using a dyno with a load simulator...and don't mess with it to much because seat of your pants tuning will get you in trouble!
Do you have a laptop with the software installed and the correct connectors (9 pin serial with no adapters) ?
What are some of the performance shops you have suggested? About how much do they charge???
DriftinCO said:
I have an OBDII reader...are you coming to the dinner in Castle Rock Thurs?
No I have to work, but if i could use that it would be great! does anyone have a A/f guage I could borrow as well. I was about to buy both from urd, but would rather not if I only need to tune them once (hopefully it is only once).
I have a laptop, I'm pretty sure the software comes with the ftc. Other than that I'm not real sure what I'm doing.
Bump for your cause, because I will soon be needing to do the same thing.
Well I just ended up buying the obdII and lm-1 a/f guage from urd as they gave me a pretty good deal. I still may need some help tuning if anyone knows anything about it all???
Discussion Starter #10
I ended up buying the obdII anyways, as i though it would come in handy for more than tuning, as well as the lm-1 a/f guage, but thanks for the offer.
Discussion Starter #12
I'm going to bump this for myself. I could probably use some help with the install and tuning, if anyone could help me it out it would be great. I'm looking at either june 4-5 or june 11-12 more than likely. The install I think will be fairly easy, I'm more worried about the tuning than the install.
Discussion Starter #14
PM me your number and I'll give you a call.
1 - 15 of 15 Posts
