1 - 3 of 3 Posts
Hey guys, i need a hand figuring out what gears i have now and what i should end up going with. I have a 97 2.7 s/b standard cab tacoma i just bought. From what i've read on here it sounds like most came with 3.58 gears. Is there any way i can confirm this from the VIN plate on the inner driver side door? There is a guy local to me who has 3.90, 4.10, and 4.30 gears for sale for 4cly and 6 cyl. toyota trucks 8". My tires are 265/75/16 m/t and the truck seems geared very high when i drive it. I'm not a diehard offroader and will use my truck as a daily driver too. Can you guys help? The truck is a 5sp. Thanks,
chances are your truck has the 3.58's since it is the 2.7. but could very well have the 3.90's I know that doesn't help.
But for your size tire and what you described as your driving patterns. I would go with 4.10's. 4.30's would be okay, but you are going to have some higher highway RPMs.
Check your VIN tag on the bottom row for some numbers like B02A. If thats what you have, then your gears are 3.58s. Look at our Tech/FAQ for the full chart of other gear ratios.
I didn't look up what size the 265/75s are, but if those are 32s or 33s, then 4.56 gears would probably be a decent choice. Those gears your local guy has are probably for the older style trucks, so watch out. The Tacoma models use a 8.4" / 210mm ring gear set in the rear (w/o the e-locker), and 7.5" RR gears in the front.
1 - 3 of 3 Posts
