Last night i started experiencing a lot of vibrations coming from my rear end and when I got out and put my hand on the differential it was really hot, anyone have any suggestions as to what the problem is?
Check for up and down play at the pinion shaft, as well as excessive back lash between the ring and pinion gears. Hopefully it's only a bad u-joint; the rear end is usually hot to the touch after driving any real distance.
There is absolutely no up and down play at the pinion shaft, no excessive backlash and all the u joints seem to be fine
