Hi guys ,
i've got a couple of question's , first the info 91 toy 4runner 4x4 v6 5sp /with a/c
I discovered a fuel leak at the fuel tank, the main supply line was rusted where the clip holds the line to the frame and also where it goes into the tank assembly. I've got the tank removed, not to hard to do, but not fun either :rolleyes: , My first question is this common problem? and is there any recalls regarding this problem? if not oh well , but i need to get the replacement assemblies, can any tell my a good souce other then the dealer for this? I did check the sponsor links already but no luck :( and last but not least how much should it cost? if someone has a used one let me know.
ps i did a search on already & zip
Try a local bone yard thats where my buddy got a replacement for his 92, his wasn't a rust problem though, got a little to crazy over in Utah. As far as them rusting out, don't really know if cancer is a common problem on them or not.
98 Taco said:
buy yourself the Toyota factory service manuals
they will help you troubleshoot common problems
good luck!
Huh?? whats a manual? ;) ....Got one but I'm more curious if it has been recalled or if there's been any fires associated to this problem, To me this is something that should not be rusting out considering that this is pressurized, and if it ruptured while you was driving .......Fried Taco anyone?
