I have a 98 2.7L 4x4 5spd. I am in the process of a SAS. I want to remove as much vacuum stuff as possible. I already bypassed the steering pump vacuum. I will need to remove the ADD vacuum stuff. Does anyone know how far I can take it with removing the vacuum lines. I would like to minimize the lines since it will be a toy. It is important that it runs well so it must be done properly but I want a clean engine bay and to remove anything that is unneccesary. Any picks would be great or vacuum diagrams. Thanks
The steering vacuum is very simple. It just closes the vacuum line when the pump is stressed. Like when you are turning into a parking spot with no throttle. The closure causes the idle to raise slightly preventing the engine from bogging down. It just so happened that I broke off one of the nipples while changing something and needed to bypass the pump. I never replaced the part and just connected the two hoses. I havent noticed any ill effects, but my truck isnt stock and doesnt act like one so its hard to notice anything wrong over the noise, wobbles, etc.
shovelracer said:
The steering vacuum is very simple. It just closes the vacuum line when the pump is stressed. ....causes the idle to raise slightly ...I broke off one of the nipples ....... never replaced the part and just connected the two hoses.
Interesting. I never knew about that. I have a 01, wonder if it's the same. I'll have to check closely. Is the vac line hooked right to the streeing? Rack? Pump?
Thanks. :)
I guess there isn't alot of vacuum line info around here.
