Awhile back my truck was not starting up properly. After a few turns of the key it would start up, eventually it began blowing the STA fuse. Replacing the fuse worked, went through a bunch! Then once the truck started up and got hot, turning it off and then getting back in blew every fuse afterwards. I got fed up and began jumping the starter until I figured out the issue. Checked wires for any damage that can cause a short. I narrowed it down to the NSS, didn't know you could open these until I just took it off. I thought it went bad, but didn't want to spend the money on a new one. Figured I could wire around it to a push button.
Instead I took it off to see whats up. The switch is located on the passenger side if the transmission, held in with a 12mm bolt and a 22mm nut. The switch tells the computer what gear the tranny is in.
Front view:
Back view, which shows the 5 screws:
remove screws (duh):
Carefully pull apart, can you spot the problem?
The contact came out some how!
Wiped off, you can see the contacts back in it's home.
Under the contacts are springs, make sure the spring is not compressed because the old grease can hold them down. Work the contacts up and down by pushing on them for insurance. I cleaned the rest of the old grease out, and used white lithium grease. You don't need much, I filled the holes that had grease in them the same way and did a quick pass over contact surface. Once that's done put all back together and test it! So far it has worked perfectly! Truck starts right up, let it run, shut off and do it again...fuse has yet to pop.
On the transmission; passenger side, near the bell housing. I know that different years have a different part number due to the electronic plug style. Other then that the part is interchangeable. I swapped my 2001 2wd onto a 99 4wd and works fine.
I've had to do this on my XJ... Is there room to move the switch in such a way that you have to worry about getting it lined up properly when you put it back on? On the XJ i had to check continuity on different terminals depending on which gear the transmission was in to make sure it was lined up right.
If you look at the first pic you can see that it is "keyed". When you do this you want the truck in Neutral which will be a vertical position and the NSS only has one vertical position to match it. Simple as that. Even if you have it in Park and the switch can only match one way to the shifter rod.
They can be a pain to adjust at times, especially when it starts to get cold outside if you take it off. It took me a week or so to finally adjust mine so it would start everytime after I swapped my trans.
Did you have any issues getting the NSS in the right adjustment? I replaced my NSS on my 2007 Tacoma and I dont think its adjusted correctly...because it ran well for 3 weeks and now is doing the same thing.
I currently have the Toytec 3'' lift with Dakar rear springs. This has allowed me to get by with 33''s, but of course they rub a bit. I am going to do a SAS coming up over the next couple months and was looking for a bit of advise. I know there are tons of threads on the matter, but I don't...
5VZ-FE Load Hesitation, Stutter, Sputter *SOLVED*
I've been chasing this engine stutter for about 1 week now. When parked if I rev the engine with more than 1/2 throttle it will sputter till about ~2,000 RPM. It feels like a misfire with out the CEL. The best way to explain it is a popping...
hello
i bought a used 2004 double cab auto with what looks to be an inchworm taco box with a 4.7 kit and inchworm adapters connected to a stock push button transfercase. i drained the first case and it looked like looked like a half a quart of redline gear oil. the rear case had two quarts of...
My truck seems to have a problem with the throttle at 2300 RPMs or below. If I accelerate slowly it bogs and sometimes will "pop". If I stomp on the throttle it runs fine.
Background: I had a rebuilt 2.7 motor installed in my 98 Tacoma Excab. The original gave out at 538k miles. While...
Is it possible at all?
So was wondering if there was a trick to quickly replace the thermostat without having to drain the whole thing.
How much coolant would it spill out if disconnecting hose from old thermostast without draining radiator?
Is it worth the try? Too messy?
Parking on the...
